06-07-2021, 22:18
Ciao a tutti,
vi segnalo, a [hide]questo link[/hide] il lavoro di un italiano in quel di Svezia che si è costruito un sistema stereo a batteria per la barca niente male, praticamente una versione 2.0 del centotrucchi
Di seguito le sue istruzioni
spero torni utile a qualcuno, io non lo escludo questo inverno!
spero torni utile a qualcuno, io non lo escludo questo inverno!Citazione:I used:
- a Raspberry Pi (https://www.raspberrypi.org/)
More exactly a Raspberry Pi 3 Model B+, but other models can be used too. See the HiFiBerry Amp 2's specs for the supported platforms
- the amplifier for Raspberry Pi: HiFiBerry Amp 2
https://www.hifiberry.com/shop/boards/hifiberry-amp2/
- a pair of passive speakers. I reused the ones from my Marshall Stockwell that I forgot outside under the rain and that didn't work anymore.
Here is a description on how to connect all together:
But I used the mediaplayer software Volumio, instead of HiFiBerryOS
https://volumio.org/volumio-overview/
Here is a guide on how to download and install the Volumio software
Actually it is all you need because you can control it via your phone
But I also added a 7″ touchscreen display for Raspberry Pi
Here is how to use it with Volumio.
I used a cheap pine wood board that I cut using the cabin door as template, which I then painted with Wood stain Lacquer.
